Player 2.9.0 Release - October 2025
Version 2.9.0 of Desktop Player will be available as of October 4th, 2025 at 9 PM!
Key Points:
  • Player support for torque multi tool driver :partying_face:
  • Phidgets supported on the Driver SDK. It will be available as a driver :soon_arrow: .
  • Player 2.9.0 is the last supported version of Player for Macs with Intel Processors. See more details here.
If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
