Player 2.6.2 - September 2024
Version 2.6.2 of Desktop Player will be available for download by 9:00 PM ET (September 23rd, 2024)! If you have auto-updates enabled and are on the biweekly release, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
