Version 2.5.1 of Desktop Player will be available for download by 9:00PM ET on February 17th, 2024! If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu. Alternatively, you can manually initiate the update process.
