Version 2.8.1 of Desktop Player will be available for download after 9:00PM ET June 9th, 2025! If you have auto-updates enabled the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
