Quick navigation & transparency for functions
When testing the functions, I noticed the following points and areas for improvement:
1. Link to the function from the app
I discovered that you can jump to the function you are using from the app menu – however, the link is only accessible via the app versions and not directly in the trigger or the app in the editor.
Suggestion: A direct link to the function in the trigger editor would be much more intuitive and would speed up navigation.
2. Use & execution of functions
Currently, it is not clear in which apps a function is used, when and how often it is executed.
Suggestion: An overview with a list of the apps that use the function (ideally also with links) and executions.
Advantages of both suggestions:
  • Faster navigation and editing
  • Greater transparency for complex app structures
  • Better maintainability and error analysis
Hi @pwied thank you for the detailed feedback.
Very insightful!
For #2 - great news! We’re planning a “Where Used” for Functions, similar to the experience for Connectors. This will be part of GA (General Availability) and we’ll implement over the next few months.
For #1 - this is also on our radar! Jumping directly to the Function definition from the App Trigger was a “nice to have” on our list for GA, so your feedback is a very helpful sanity check.
We’re keeping an eye on upvotes to guide our prioritization. Please keep the great Functions feedback coming!
-Olga
