Scrolling Expression
Hello all,
The scrolling in the expression editor is not working properly, does anyone know of a solution?
If you move the scroll bar down and then back up a little, it will go back to the top.
Hello, @da-noguchi
The expression editor is functioning properly, and there isn’t a known issue with scrolling. If you’re experiencing difficulties, consider checking for any updates or reaching out to the support team for further assistance.
