When selecting a table aggregation as the datasource for a variable widget, they are not sorted in any way, which makes it incredibly difficult and tedious to find the one you’re looking for.
When you only have a few aggregations it’s not a big deal, but I’m creating a dashboard app that has quite a lot, and in situations like that it takes a really long time to look through the whole list.
If there was a search function or auto-sorting by alphabetical or time added that would be great.
Thanks!
