View Table Aggregation Values in Dev Mode
It would really help to be able to see the values currently stored in table aggregations in Dev Mode without having to set a separate variable or embed a variable text onto the app UI. Maybe add a third pane next to “Variables” and “Table Records” on the bottom left?
Thanks for the suggestion @John :slight_smile: . We will investigate some options to help with this.
