Editable Test Values in Dev Mode
Debugging across apps and tables in larger solutions in Dev mode can be tough if there are dependencies between applications. I would like to be able to enter “dummy” values into variables and tables records in Dev Mode in order to make debugging single steps easier.
The use-case here came up in office hours today. The user (@don.feeney) has one application that collects a value at the end of a long process. In another application, a different user needs to enter a similar value. If the second value is out of a specified range calculated from the first value, a quality event is triggered. In order to test this, the user has to go into tables manually to update several columns in a table, or commit to running the first application every time.
If they could just enter the values they want to test against, this could be solved.
