Debug automations
Hello,
I’ve created very complex automation process that uses nested loops (one external loop and one internal), gets data by loop element value from a table, update variables it by several conditions logics and finally update a Tulip table for those variables and much more.
Only way of debug currently available is sending mails with current data of variables, not comfortable at all and very furstrating.
Can anyone write down when a normal debug mode will be available ? or even local variable current values during process run will be enough.
Thank you,
Amit Berku
Hi Amit!
Very valuable feedback, and acknowledge the frustration. We have a project on the roadmap for adding more Debugging and Traceability to Run History. The full project could take longer to deliver - possibly end of 2024, or early 2025.
Would you be up for a quick call about your use case, to review what we’re proposing, and also to chat about your ideas for local variable values? Thanks in advance!
  • Olga
Hi Olgo,
Yes, ofcourse, suggest times for a meeting.
My working days are from Sunday to Thursday, I believe that your are from the Boston office, so put the schedule early times of your local time (I’m from Israel).
Amit
Thank you for coordinating! Looking forward to connecting today!
