Automation Run History - Ability to review what values were saved into any variables used in the automation
I think it would be really helpful if you could view what the values of variables were within the automation workflow after the automation completed as this would aid debugging an automation.
As a workaround I could probably implement a table and connector function to store variable data.
Hi John,
Are you referring to the variables that are created within automations or the values that are used within a function and get written somewhere else?
Jake
Hi Jake,
It would be nice to view a completed automation to see what the values were of any variables that were used within the workflow, and possibly the outcome of a decision tree in some sort of visual way.
Hi John,
Agreed - we’re thinking about how best to implement this longer term.
Jake
