It would be nice if automations had the option to restore previous versions, as currently, they can only be viewed. Additionally, when an automation is published, it doesn’t prompt for any comments, making it difficult to track the exact changes made, which makes reviewing a bit challenging.
Thanks @emendoza , this is on our radar, but we were hoping to invest in a richer Run History debugging experience first, since folks can still see the older versions and manually rebuild them if needed — but without that richer run history, tracing out what errored out and why is quite hard.
Does that prioritization sound right to you?
- Olga
