Greetings.
One of my customer started using automations. At some point I needed to check if an error had occurred after some of them had been run for several months. Unfortunately, the best I could do was browse by hand dozens of run history pages, hoping not to miss an Fail, Limited or Timed Out status…
It would help a lot if one could filter an automation’s run history by status. Ideally, also by start/end date and by automation version. Having a column with the execution’s duration, one with the number of self-triggerings and CSV export would also be nice to have.
