String array not equal string array
i ran into a weird logic in the expression editor which can be summed up into “an array of strings is not of the same type as an array of strings”.
I found this behavior when we tried to use the LINK-function on an aggregation of IDs and a string array to check quickly if the aggregation returned a blank value.
Is there a reason for this behavior?
Stanislaw
Hi Stanislaw,
Thanks for bringing this to our attention. I talked with the team and this actually looks like a bug. I have created an internal ticket and our team will look into getting this fixed!
Thank you very much :slight_smile:
@sloschitzki Just wanted to follow up with you that this has been fixed in Release 277 - April 2024!! Thanks for pointing this out to us :slight_smile:
