String manipulation
I have a string in a table containing a list of serial numbers; this list could be a list of 1 or >1. I will need to develop functionality to find a particular serial number and remove it from the list while keeping the integrity of the comma delineator. This will be very easy if the list contains 1 SN, but I am unsure how to achieve this if the qty is >1. Any help or guidance would be greatly appreciated.
Example string:
AA4B109210101, AA4B109210102, AA4B109210103, AA4B109210104
SN to remove – case 1:
AA4B109210103
New string – case 1:
AA4B109210101, AA4B109210102, AA4B109210104
SN to remove – case 2:
AA4B109210101
New string – case 2:
SN to remove – case 3:
AA4B109210104
New string – case 3:
Hi @RDuke,
if it is always the same pattern (Komma and Space) here is one possible way with TULIP Expressions:
The Button Trigger does:
However, it might be a better solution to manipulate the “removeFromList” and the “listBefore” strings before by adding a ", " at the beginning and the end, then substitute and trim the ", " at the ends again.
That makes sure, you only substitute complete Serial Numbers…
like so:
Thank you for your quick response, this is exactly what I was looking for!
