Tagging or Naming Of Widgets within a step
For steps that have a large number of widgets, it would be nice to be able to “name” or tag the widgets in some way. When you click the dropdown arrow for the step to display the widgets within the step, currently the widget type “Text” “Variable” etc. is displayed, but there’s no way (as far as I can see) to differentiate between multiple widgets of the same type to select a specific widget without clicking through all the “text” widgets for example, until you find the correct one.
Having the ability to keep the icon for the widget type, but rename the widget to something meaningful would be helpful.
Hey @richard.vaughn -
My first thought too when I noticed widgets in the step tree, thankfully this is coming very soon, along with a bunch more features to make widget management easier! Expect more to come in the next few releases.
Keep the ideas coming!
@richard.vaughn Just want to circle back and say the ability to rename widgets is now possible in r267! Thanks for a great suggestion here :slight_smile:
You can check the release announcement out here Release 267 - November 2023
