Tulip Common Data Model in Snowflake - SQL Code
Sharing this SQL code here as a reference for folks. It will create a version of the Tulip Common Data Model in Snowflake.
I wrote it as I built an integration between Tulip and Snowflake and thought.
It can be easily adapted to work in other SQL databases.
Let me know if you have any comments.
Very cool, Eddy!
For posterity, there is a library here which can be used to quickly translate SQL scripts across different dialects.
