How to get data out of Tulip and into a SQL Server
Hello,
Is there a simple way to get data out of Tulip and into a SQL Server using a connector function, or other means? If it isn’t possible to do with a connector, but there is another solution, is there a demo that could be shared to better understand how to handle this inqury?
Thank you for your help!
Taylor
Hey @txh3467 ,
This is certainly possible! You should check out these articles as a next step:
Let me know if you have questions while getting set-up!
Best,
Kailey
