We already talked about migrating app to another instance here:
Is there a way to migrate finished app (with tables) to different tulip instance?
We have instance of tulip for development, testing and “know the environment” purposes and also we support larger company with their own instance. So we would not like to “spam” their instance with some temporary apps or tables.
I know that some things probably have to be configured when moving apps but I would like to now in general if migrating apps is possible and how.
Thank you.
I’m currently working on app using SQL server and I have few connector functions. I’m afraid that number of functions will grow.
Can connector functions also be migrated to another instance.
Thank you, Ermin
gio
June 12, 2021, 9:43am
2
hello @ermingut , thanks for posting!!
while there’s no way to individually copy Connectors Functions between instances, Connectors and Functions are copied over when you Copy an App that makes use of them.
let me know if you have further questions!!
Thank you. This is all I need to know.
Ermin
