Is there a possibility in Tulip to link Exact online?
Does anyone have experience with this?
Hey Henk,
I don’t personally know of a customer who is using Exact Online (but there may be some), but it looks like they have a REST API (documentation here) so my recomedation would be to set up a http connector function to call their api.
In your instance you should see a “Google GeoCoding” connector that will work basically the same way as your connector.
https://support.exactonline.com/community/s/knowledge-base#All-All-DNO-Content-restrefdocs
Here is a really good document that walks through setting up an API connector, it will differ a little based on the API (so Exact online might differ some), but the process on the tulip side will be very similar.
Let me know if there is anyway I can help more-
