Is it possible with tulip-machine-attribute to sens several attributes in one request? I can do it with the standard HTTP Node but not with the Tulip node. Thanks for your help
Not currently, but I’ve added a feature request to our work to make NodeRED more scalable and to see if we can fit this is in when we’re touching that portion of the code base.
For example, a SparkplugB device can send several metrics in same payload. If often the case with smart tools that doesn’t generate data continuously but send a batch of data after an event (screw driver, quality équipements, …)
