Hi All,
We have a use case where we want to write boolean into a machine attribute and to use this machine attribute to run a flow in Node Red (running on an EDGE IO).
The machine attribut we are using is a boolean. We want to send the data TRUE thanks to a button in an App and get the data TRUE in Node Red.
The issue that we have is the following :
When we press the Button in the App, we have an error message.
Here are the Config of the Machine Attribut used :
My guess is that the problem comes from the Data Source.
Any help on what I should do ?
Paul
