I have an App I’m developing to create an oven chart recorder to digitize the current process.
The oven controller is not “smart” but I’m pulling Temperature Setpoint, Current Temperature, and Controller Output (%) from the controller via Modbus.
I’m trying to add logic to the app such that once the operator presses “Start Process” and goes to the next step, that it checks that Current Temp == Temp Setpoint before putting the “machine” in the Running state, but it doesn’t appear that I can do that currently.
If I add a trigger in Machines and Devices, I only get access to the attribute I set as the trigger, but I have a boolean attribute called Running that I want to change to TRUE when the oven is effectively in cycle.
Is there an easy workaround?
