Unable to Access Microphone in Tulip Custom Widget
Hello Tulip Community,
I am facing an issue with microphone access in my custom widget. The code works fine outside of Tulip when using the microphone, but inside Tulip, the microphone is not accessible.
Has anyone encountered this issue before? Any guidance on resolving it would be greatly appreciated!
Thanks in advance for your help.
Best regards,
Sagar Burman
Hi @sagar007 -
You are encountering a current limitation of Tulip Custom Widgets. However, I have good news! The team has been working on this already and the ability to access microphone from a Custom Widget should be coming in a month or two! Check out this announcement for a bit more detail: Custom Widget Improvements
If you want to play around with this now, we could actually enable it for you early. You should reach out to your Customer Success Manager and they can work with you to get that set up :slight_smile:
