I know you can use elapsed time (from the ‘App Info’ dropdown), but I’ve run in to a couple situations where I wanted to use the planned cycle time in some expression or table and found myself unable to. Let me know if there is something I might be missing…
Hi Bryan,
Is the planned cycle time a variable that you created? My guess is that you might be running into issues with mis-matched types. I would make sure the Planned Cycle Time variable is of the type ‘interval’ and you should be able to use it in conditions and expressions. Let me know if you are still having issues.
Sorry no, I meant the step cycle time that you fill out for each step - in the app editor on the right pane under the “Step” tab.
Understood! Thank you for the clarification. I have submitted the request to the team
