Using EDGE IO USB as an Output
Hello all,
Anyone has already used the EDGE IO USB to output a data on another device ?
Is it possible to do that using Node Red ?
Thanks a lot,
Paul
Hi Paul!
There may be two options here:
  1. Send data through Tulip, by sending the data from Edge to Tulip β†’ using Tulip to send to your device, ie through a connector (caveat, this is very inefficient)
  2. As you suspected, you could use Node-RED, this article should be able to help How to: Use Serial with Node-RED. A note here: hot-plugging isn’t supported (device must be plugged in when node-red starts for it to show up)
Does this help?
Hi Beth,
Thanks a lot for the inputs !
I will try the option 2.
Paul
