I haven’t tried it yet, but is it possible to insert a micro SD card into the Edge MC and read/write to it from Node-RED like you can when you have Node-RED running on Linux or Windows?
Hi @Alan.Madorin,
We explored this option in earlier versions of the OS but will not support these options in future updates. Is data logging a critical feature for your application?
No, I don’t think it would be required. I can just pass data along to another device on the network or into Tulip.
