3rd party program to map out triggers?
Some of our apps have a good number of triggers per step. After a while it gets a bit difficult to keep the whole flow in my head. I’m wondering if anyone uses a 3rd party program to map out triggers. Something so you can see how all the triggers look on one page, and how each trigger connects/relates to other triggers?
I have access to Lucidchart ( Intelligent Diagramming | Lucidchart and was thinking about using it, but I’d love to hear how others are tackling this!
Hi @jasonh,
Check out this product suggestion thread - Automated plotting of app transition flows.
Sincerely,
Jake
wow, that’s what I’m looking for. Unfortunately we’re on LTS. With that said, it will be something to look forward to!
Thanks Jake!
Hi @jasonh,
Just to be clear - this is not something that we’re currently building but are interested in better understanding.
Sincerely,
Jake
@sebme would you be willing to share the script tool you made in Automated plotting of app transition flows for others to use as an interim tool?
Hi @jasonh , is this still a problem for you? If so, would love to interview you to learn more. I am starting to plan out a solution to this problem.
We utilize Lucidchart for mapping out process flow and table schemas. It would be awesome to have something built into Tulip! Yes, let’s connect.
This feature is now available via a JSON file in the “Inspect App” feature. Check it out here: How to Inspect App Logic (Experimental)
Do you have to be on a specific LTS or release to have this feature flag turned on? We’re on 13.2 as of now.
It is on LTS14 and later.
