Ability to add custom SVG icons to standard button widgets
Please add functionality to allow a developer to add custom SVG icons to standard button widgets… Like an upload slot where one can point to an SVG file.
Having to go through the layering approach is horrible. Especially as there is also no way to group things at present (another critical request nevertheless raised earlier).
Custom widgets are no good replacement because their sandboxing quickly eats resources if used a lot.
Clarification follow-up: I am fully aware of the ability to add triggers to images. This is not a reasonable replacement.
@sebme I agree with you, I use this a lot…
Have you checked this widget out? (I haven’t experienced the sandbox / resource concern you mentioned when using this)
It would be great if we would be able to add our own specific icons to a standard button widget
