Are there any temperature sensors compatible with Tulip that can measure up to 572°F?
I’m looking for sensors that work with Tulip Edge IO, ideally with plug-and-play functionality
This exceeds your temp requirement and has RS232. I’m not sure if it’s been tested with Tulip though:
Thanks!!
For me looks like it is possible
@emendoza
In this Community post, I discuss using a thermocouple by Phidgets. One example thermocouple on their site is rated up to 400 C.
I hope this helps,
Tim Reblitz
Tulip | Digital Transformation Consultant
Great! thanks for the reply.
