Simple Sense & Respond enabled by Tulip Automations
Hi all, I’m Tim and work in the Tulip Services team as Solution Lead.
This video tutorial is on enabling a simple ‘sense and respond’ use case using third-party Phidgets devices and Tulip Automations.
Use Case: Bake bread until the internal temperature is 190 ℉, then promptly pull from the oven to prevent over-baking.
Solution: Tulip Automations workflow triggering an SMS when the temperature from a third-party Phidgets thermocouple reaches a value as saved in a Tulip Table record.
