For GMP Validated instance, it’s good that it gets logged out automatically frequently when not in use or idle on the backend. Instances looks very similar to each other and it’s easy to make a mistake on prod by accident by admin
Hi @chieumaihong -
Thanks for your request here - his is actually currently possible (as of LTS12)!
In your Tulip Instance, under Account Settings > Account page you should see a setting where you can set an inactivity timeout!
Tulip users will then get a pop up prompt letting them know they will be logged out after the specified period of inactivity:
As an FYI, you can also configure player to auto log out (here: Configure Your Tulip Account Settings)
