I was trying to work through a concept for Automations. Right now I have a several Edge MC’s that will be interacting with the same App. The plan is to set up a connector to interact with Edge MC.
My goal is to use an automation to route the data that would trigger the appropriate connector. The question I have is if a connector takes about 500-600ms to engage, will the automation add any time to the operation?
Thank you for your question! It sounds like you’re thinking about how to get data from your Edge MC at a particular point in time. Does your intended flow look something like this?
Application(to kick off the automation) → Automation → Connector → Edge MC → Automation → Tulip Table
The automation does take time to respond to an event and then execute. A time-sensitive event should utilize machine triggers or machine events when they are released.
I have a few questions for you that would help me better understand your intended use:
What’s the importance of the datetime - are you trying to use it as a unique identifier or for another reason?
Is your application time-sensitive or are you curious if automations take a few seconds/minutes/hours to run?
The application would be time sensitive. My goal is to use the Edge MC to communicate to a PLC. In this specific case it would be a trigger that would come from an operator to initiate an event. In this case, would Automations add on several seconds this operation?
Automations isn’t a time-sensitive application - it sounds like you need to record the time that your request was triggered from the application. Automations run time could range from seconds to ~several minutes.
If you’re concerned about tracking OEE, I would recommend that you utilize the timestamp from the operator as the event kick-off. If you’re worried about latency between that trigger firing and when the PLC receives the event, I would push towards automation machine events or a machine trigger.
