Base layout triggers should be visible on steps
Triggers on the base layout (On step enter, On step exit, …) are not visible in the actual steps.
Triggers on buttons that are on the base layout, are visible in all steps. It would be clearer if this was the same for triggers on steps.
A next step nice to have, could be the possibility to edit/remove that trigger after unlocking it with the lock icon. Same as you would do for widgets on the base layout.
Completely agree with this. Thanks for the suggestion.
Hey @jef.vanhoutven , happy to say this has been rolled out in r366!
