Hello there,
I would like to knw if there is any way to make bigger the size of the axis in my dashboards. When I connect to the app it is pretty difficult to see the numbers and letters in the axis. See an example:
thanks so much¡
hello @Judyth while the size cannot be modified on the analysis itself, I see that it’s embedded in an app. have you considered adding Static Text with the labels for the axis in the app??
let us know if that would work for you!!
Thanks @gio for this dashboard/graphic I can do that. However, I have another analysis that require to be updated anytime:
How would you do it?
