Both the Trim and Substitute functions do not work well with parenthesis
The end of one of my fields has extra text at the end of it (half the time) that i want removed. in trying both the substitute and trim functions, i found that it does not work without doing it in a roundabout way
The original attempt as shown in the above screenshots, either removes extra text that i want to keep, or doesn’t remove anything.
but if you trim just ‘15th)’ and then again trim ’ (’ it will work (The substitute will not do this and errors out)
Thanks for posting. Let me connect with the team to understand whether this is a regression or a known limitation.
For the Trim() it seems, that _is an issue, when removed in the original string. It will also remove everything before, to the next space:
This seems to apply to a space character as well!
But I can’t see issues with parenthesis here.
For Substitute() keep in mind, that some characters as ( ) [ ] \ and others need to be escaped.
The escape character is \ but it also must be escaped with an extra \
I’d been trying to escape with a single backslash this whole time! thank you for that!!
however, the issue is still that spaces are left with your final image
if i were to use right 2, then is grabs the 1 as well
So while the issue isn’t the parenthesis like i initially thought, the space(s) being left after a trim is definitely still an issue
Workaround would be:
TRIM(TRIM(@Variable.Begin Text 1, '(15th)'))
You don’t need to escape the ( & ) in TRIM() :wink:
