Hello everyone.
Some of our customers regularly express the need to limit access to certain apps/features/behaviors for users, based on business-defined roles/permissions. We are not talking about Tulip instance permissions (edit an app, publish an app etc.) or roles (Account Owner, Operator etc.) here.
This implies answering several questions.
Q1) What kind of data structure should we use to store permissions?
Usually, this is done by defining a set of boolean permissions and assigning them a value (true => granted, false => denied) for a specific user. This could be done:
- directly (custom per-user rights, but this is tedious to input, repetitive and harder to maintain),
- using a role (user is mapped to a role, the role is mapped to a set of boolean values for permissions, e.g. true everywhere for an admin role)
- a mixture of both if we want to go far (e.g. we rely on the user’s role for most permissions but have user-specific values for some of them).
ID |
Can order new supplies? |
Can delete a product? |
admin_role |
true |
true |
accounting_role |
true |
false |
Role-based approach example (Role permissions table)
ID |
Role |
alice |
accounting_role |
bob |
accounting_role |
charlie |
admin_role |
Role-based approach example (User roles table)
Q2) How to store permissions so they can be accessed from any app?
- a Tulip table could be fine, but it becomes impractical if user roles/permissions must be accessible across all workspaces of an instance
- a connector to a REST API or SQL database could do it but it’s much more work and setup for unclear benefits
Q3) How would the access restriction manifest?
- by limiting access to an app to users having a specific role/permission (with an “App started” trigger?)
- by limiting access to some steps in an app (with an “On step enter” triggers?)
- by limiting access to some in-app behavior (via a test in a trigger?)
- by hiding a control (is this possible?)
Currently in Tulip, it seems we must do many things manually. Any tip/thought/experience feedback about any of these questions (or other related ones) are welcome from anyone (Tulip team or not) and will be greatly appreciated.
Thanks!
