Need a way to convert the case to either all upper case or lower case for a text user input?
Use this widget to convert text input to the desired case. The conversion is realtime and thus helpful for table filters (for equal to or not equal to filter types).
Additionally it has a Trim option to remove any whitespace from the start or end of the input value.
Widget: Case Convert
Version: 1.0
Date: Oct 12th 2022
customWidget-Convert Case.json (5.6 KB)
