Case Insensitive Filter
Hi there, I just started coding with Tulip this week.
I’ve built a filter to search a table. However, I realized it’s case sensitive. How can I make it a case insensitive search filter?
Hello @symym,
There is no filter here that would encompass all cases of being case-insensitive. However, if you are only concerned about the first character of a string being uppercase/lowercase, you could use the expression editor to create 2 new variable which would essentially convert the ‘bag’ to ‘Bag’ and check if this exists in the table.
After this, you could set up a filter on the interactive table as below:
This approach would work with the assumption that we are only considering the first character to be case-insensitive. Let us know if this would help you!
Thank you,
Het.
