Tulip filtering case sensitivity?
Is it possible to make a tulip table filter so that it is not case sensitive?
Hi there!
If you use the “contains” filter, it is not case sensitive. If you use the “equals” filter, it is case sensitive.
Does this help?
Yes it works now , thank you!
Awesome!
I realized we probably could have this documented better in our Knowledge Base, so @L_Churchill and I will work on that as well :slight_smile:
