Checkbox Widget
When I use checkboxes, I almost always use the same text for the label and variable’s name of data source.
So, if I input the text to label, I would like to make variable automatically.
For example, if you input the text to label and check button to make variable or something, the variable with the same name will be make automatically etc.
Hi @ai-ohara thanks for your product suggestion. This is a good idea, and we will incorporate this into our planning for making building forms with all input types much easier.
If you have any further suggestions with building forms in Tulip Apps, please let us know!
