Complicated analystics
Hello,
You can’t make graph using more than 2 paramets for the x & y and maybe another parameter in the filter, if I have a table that contains several types of data to be shown, like machine type + qunatity per hour + min value + max value, and I want a line graph, I can’t do that.
You can create a complicated exspression that will combine some fields together by some kind of logic but if I want to show more than one value on the X, I can’t do that.
For example, I have a sausages fill machine that have a minimum and maximum quantity per hour, I want to see a flow line graph the let me know if I’m between those numbers or got up or down from them during the day.
Thank you,
Amit
Hi @Amit we are always looking at ways to improve the analytics that you can create in Tulip. Thanks for the example!
