Connecting to Bluetooth Serial Devices
Hi there. I am a newer user of Tulip and am in the process of developing an application that captures torque values from a digital torque wrench. The wrench communicates via Serial Bluetooth. Just FYI I have very limited knowledge when it comes to this kind of topic.
I can connect the device via Bluetooth and use a program like PuTTY to confirm it is transmitting data. I just need to know how to connect this device with the Tulip player to be able to send data to the App and store into a variable. Is this something I would need and Edge IO device for? Is there another way to do this without an Edge device?
Thanks in advance for the help
I haven’t tried this over bluetooth but we have connected various devices (Mountz EZTorQ torque analyzers, Zebra printers, TEEMI barcode scanners) over USB as serial-connected devices using the Serial (Player Only) device connections and these work quite reliably. If you search community for “serial” you will find some prior posts.
Thanks for the recommendation.
Here is the link that I was able to use for my solution: Using the Serial Driver
