Connecting two Apps
Hi ,
How can I connect or link two apps?, We have an app regarding quality issues and we want to sent to another app (maintenance orders) to create a task.
Thanks in advance
hello @LXM8843, welcome to the Tulip Community!!
are you familiar with the following Transition??
App > Complete App and Change to Step
here’s how it can be used:
let us know if this is what you meant by linking two apps!!
Hello LXM8843 ,
You can use another application called “menu” where you let the choice to select the app desired.
Yes Gio , it worked! Appreciate it!
Thank you Math :slight_smile: , it´s resolved
