Custom Widget does not refresh on step enter
I’ve put together a custom widget for a gauge meter.
I’ve set up a button to refresh the step, but when refreshing the widget doesn’t change with the new variables.
JS:
// setup
getValue("min", (x) => {
 min = x == null ? "" : x;
getValue("text_color", (x) => {
 text_color = x == null ? "" : x;
getValue("lolim_color", (x) => {
 lolim_color = x == null ? "" : x;
getValue("mid_color", (x) => {
 mid_color = x == null ? "" : x;
getValue("hilim_color", (x) => {
 hilim_color = x == null ? "" : x;
getValue("lolim_label", (x) => {
 lolim_label = x == null ? "" : x;
getValue("mid_label", (x) => {
 mid_label = x == null ? "" : x;
getValue("hilim_label", (x) => {
 hilim_label = x == null ? "" : x;
getValue("engunit", (x) => {
 engunit = x == null ? "" : x;
getValue("max", (x) => {
 max = x == null ? "" : x;
getValue("lolim", (x) => {
 lolim = x == null ? "" : x;
getValue("hilim", (x) => {
 hilim = x == null ? "" : x;
getValue("value", (x) => {
 value = x == null ? "" : x;
const data = {
  labels: [lolim_label, mid_label, hilim_label],
  datasets: [
      label: "Gauge",
      data: [lolim, hilim, max],
      backgroundColor: [
        lolim_color,
        mid_color,
        hilim_color,
      needleValue: value,
      borderColor: "white",
      borderWidth: 2,
      cutout: "95%",
      circumference: 180,
      rotation: 270,
      borderRadius: 5,
//gaugeNeedle
const gaugeNeedle = {
  afterDatasetDraw(chart, args, options) {
    const {
      ctx,
      config,
      data,
      chartArea: { top, right, bottom, left, width, height },
    } = chart;
    ctx.save();
    const needleValue = data.datasets[0].needleValue;
    const dataTotal = data.datasets[0].data.reduce((a, b) => a + b, 0);
    var angle = Math.PI + (needleValue/max) * Math.PI;
    console.log(angle);
    const cx = width / 2;
    const cy = chart._metasets[0].data[0].y;
    //needle
    ctx.translate(cx, cy);
    ctx.rotate(angle);
    ctx.beginPath();
    ctx.moveTo(0, -2);
    ctx.lineTo(height - ctx.canvas.offsetTop - 160, 0); // change 160 value if the needle size gets changed
    ctx.lineTo(0, 2);
    ctx.fillStyle = text_color;
    ctx.fill();
    //needle dot
    ctx.translate(-cx, -cy);
    ctx.beginPath();
    ctx.arc(cx, cy, 5, 0, 10);
    ctx.fill();
    ctx.restore();
    //text
    ctx.font = "24px Ubuntu";
    ctx.fillText(needleValue +" "+ engunit, cx, cy + 50);
    ctx.font = "14px Ubuntu";
    ctx.fillText(min, 55, cy);
    ctx.fillText(max/2, cx, 155);
    ctx.fillText(max, (width-55), cy); // change values if the position gets changed
    ctx.textAlign = "center";
    ctx.restore();
// config
const config = {
  type: "doughnut",
  data,
  options: {
    plugins: {
      legend: {
        display: false,
      tooltip: {
        yAlign: "bottom",
        displayColors: false,
        callbacks: {
          label: function (tooltipItem, data, value) {
            return tooltipItem.label;
  plugins: [gaugeNeedle],
// render init block
const myChart = new Chart(document.getElementById("gauge"), config);
