I would like to delete many queries that are useless in one of my tables.
When I try to delete it, Tulip says that it is used in two apps.
But both links go to the same app.
And when I go in this app, there is no query for this table.
Are these apps where the system thinks the query is active in the archive? I would try deleting the table completely from the unused app and see if that helps.
