Hello everyone,
I’m trying to clean up unused queries but when i select “Delete query”, it says that it is used on a deleted app so I can’t even go to the app and remove the query.
Thanks for your help
Hi there!
So in Tulip you cannot actually “delete” apps - however, they can be archived. Maybe what is happening here is that query is still in the archived app, so it can’t be deleted.
I think maybe if you navigated to the Archive tab in you app editor, find the app that uses that query, and remove the connection to the query within the app, maybe then you can delete the query from the table?
Let me know if that solves the issue!
Beth
That helps a lot ! Thank you
