I am creating a nice dashboard for my application, but noticed that using an analyses in app is the best way to create filters. But there is a problem right now with the solution, because when I filter tables and there is a dropdown for selecting values with equal filter it has a null state, where the filter is not applied and I can see the full table (working as intended), but if I filter the analysis the null state empties the table and you can’t see the data. I think two different ways of the same filtering is really confusing from the user standpoint and unifying them the way the tables work would be benefical.
