We mesure lead time as an interval value (difference between start and stop time).
We would like to display the average value of the lead time.
I use query + aggregation (avg function) on the table.
The value is displayed as DD:HH:MM:SS, witch is heavy for an opertor.
We would like to change the format, or display a value in days only.
i’ve tried to divide the interval by 86,400, but the result can only be store as an interval data type.
Any suggestion for this ?
Regards
Christophe
Hey @christophe.pinard, thanks for the question and welcome to the community!
Try the interval_to_seconds() function in the expression editor to get your interval into a more workable datatype. Here’s the documentation on that expression (control+F for “interval”).
Additionally, there’s a rounddatetime() expression that will give you the result you’re looking for if you can get your initial value into datetime format.
Let me know if this works!
