This might just be a feature request or I’m missing how to do this.
If I had a takt time counting down on say mqtt topic
Line1/takt
Line2/takt
Is there a way of dynamically show this machine attribute based on a variable. Or show a machine based on a variable.
Ok, writing it out it I found a janky way, you would have to use a TEXT match in a trigger to then set the machine.
I would like real variable input for the machine and the machine attribute
Hey @mellerbeck -
Right now we don’t support this sort of dynamic (app defined) subscriptions to MQTT - There are 2 different ways that we are looking to support this, on slightly different time horizons:
- Add support for wildcards in subscriptions to mqtt in machines - this is a fairly simple addition that will allow some more dynamic subscription. This will likely only support single level wildcards, as it reduces some of the complexity in robust rate limiting.
- Add a more generic, and dynamic, way to ingest events into the product without the need for the concept of a machine, which can be overly restrictive to model your shop floor. This would also be something that could be extended to support things like Tulip-hosted webhooks.
#1 is something that we are activly looking into, and #2 is something we are seriously considering for a project next year.
